например почему джейфет а не другой транзистор на приложенной схеме?
СПС
>http://en.wikipedia.org/wiki/JFET>
....Comparison with other transistors
JFET gate current (the reverse leakage of the gate-to-channel junction) is comparable to that of a MOSFET (which has insulating oxide between gate and channel), but much less than the base current of a bipolar junction transistor. The JFET has higher transconductance than the MOSFET and is therefore used in some low-noise, high input-impedance op-amps..
transconductance - это усиление имеется в виду?
