Модели цифровых микросхем серий 74ALSxx, 74ASxx, 74Sxx, 74Fxx для Proteus Pro
Сообщение Fizik_S »
Всем привет!
Делюсь некоторыми моделями цифровых микросхем для Proteus Pro.
Модели симулируемые, поэтому теперь возможно просимулировать цифровые схемы с применением указанных серий цифровых микросхем. Коллекция будет пополняться.
Список готовых моделей:
74ALS00, 74ALS00.DM, 74ALS00.IEC, 74ALS01, 74ALS01.DM, 74ALS01.IEC, 74ALS02, 74ALS02.DM, 74ALS02.IEC
74ALS03, 74ALS03.IEC, 74ALS04, 74ALS04.DM, 74ALS04.IEC, 74ALS08, 74ALS08.DM, 74ALS08.IEC
74ALS32, 74ALS32.DM, 74ALS32.IEC, 74ALS20, 74ALS20.DM, 74ALS20.IEC, 74ALS74, 74ALS74.IEC,
74ALS138, 74ALS138.IEC, 74ALS139, 74ALS139.IEC, 74ALS245, 74ALS245.IEC, 74ALS244, 74ALS244.IEC
74ALS257, 74ALS257.IEC, 74ALS153, 74ALS153.IEC, 74ALS373, 74ALS373.IEC, 74ALS374, 74ALS374.IEC
74ALS573, 74ALS573.IEC, 74ALS574, 74ALS574.IE, 74ALS175, 74ALS175.IE, 74ALS86, 74ALS86.IEC
74ALS161, 74ALS161.IE, 74ALS151, 74ALS151.IEC
74AS00, 74AS00.DM, 74AS00.IEC, 74AS02, 74AS02.DM, 74AS02.IEC, 74AS04, 74AS04.DM, 74AS04,IEC
74AS08, 74AS08.DM, 74AS08.IEC, 74AS32, 74AS32.DM, 74AS32.IEC, 74AS20, 74AS20.DM, 74AS20.IEC
74AS74, 74AS74.IEC, 74AS138, 74AS138.IEC, 74AS139, 74AS139.IEC, 74AS245, 74AS245.IEC,
74AS244, 74AS244.IEC, 74AS257, 74AS257.IEC, 74AS153, 74AS153.IEC, 74AS373, 74AS373.IEC,
74AS374, 74AS374.IEC, 74AS573, 74AS573.IEC, 74AS574, 74AS574.IE, 74AS175, 74AS175.IE,
74AS161, 74AS161.IE, 74AS151, 74AS151.IEC
74S00, 74S00.DM, 74S00.IEC, 74S02, 74S02.DM, 74S02.IEC, 74S03, 74S03.IEC, 74S04.IEC
74S08, 74S08.DM, 74S08.IEC, 74S32, 74S32.DM, 74S32.IEC, 74S20, 74S20.DM, 74S20.IEC
74S74, 74S74.IEC, 74S138, 74S138.IEC, 74S139, 74S139.IEC, 74S244, 74S244.IEC,
74S257, 74S257.IEC, 74S153, 74S153.IEC, 74S373, 74S373.IEC, 74S374, 74S374.IEC,
74S175, 74S175.IEC, 74S86, 74S151, 74S151.IEC, 74S86.IEC
74F00, 74F00.DM, 74F00.IEC, 74F02, 74F02.DM, 74F02.IEC, 74F04, 74F04.DM, 74F04.IEC
74F08, 74F08.DM, 74F08.IEC, 74F32, 74F32.DM, 74F32.IEC, 74F20, 74F20.DM, 74F20.IEC
74F74, 74F74.IEC, 74FI38, 74F138.IEC, 74F139, 74F139.IEC, 74F245, 74F245.IEC,
74F244, 74F244.IEC, 74F257, 74F257.IEC, 74F153, 74F153.IEC, 74F373, 74F373.IEC,
74F374, 74F374.IEC, 74F573, 74F573.IEC, 74F574, 74F574.IE, 74F86, 74F86.IEC,
74F161, 74F161.IEC
74HCT03, 74HCT03.IEC, 74HCT153, 74HCT153.IE, 74HCT175, 74HCT175.IEC, 7486, 7486.IEC
74HCT161, 74HCT161.IEC
Компьютер Орион-128, собранный в Proteus на этих моделях, симулируется корректно.
Установка:
Распаковать содержимое архива в каталог с установленной программой.
Модели будут с течением времени добавляться (по мере появления новых, не регулярно).
DATA.zip
(383.7 КБ) 10 скачиваний
Сообщение Призрачный Суслик »
Эххх, вот бы SN7497.....
А что существует работоспособная модель 8080/Z80 ?
Сообщение Fizik_S »
Модель SN7497 я делал для симулятора SimulIDE. Если не нужна прецизионная точность, то могу слепить по быстрому и для Proteus. Добавить ее в библиотеку стандартных моделей, теоретически тоже можно... Попробую.
Рабочие модели Z80, 8080, 8085, 8086, 8088 и много другого полезного есть здесь: http://www.nedopc.org/forum/viewtopic.php?t=19632
Для SimulIDE есть модели Z80 + ULA ZX48K, MC6502 + периферия.
Вопрос к матерым котанам: как сюда картинки добавить без геморроя?
Сообщение Fizik_S »
Модельку слепил. Реальные задержки не учитываются. Для экспериментов, думаю, достаточно.
В архиве 2 файла с проектами: SN7497 - содержит модель, SN7497_test - тестовая схема.
Проект создан в Proteus 8.17 SP5.
Для создания своих схем нужно открыть проект SN7497 и добавить в него нужные компоненты. Если нужно несколько микросхем SN7497, то клонируем их из схемы.
SN7497.zip
(304.22 КБ) 1 скачивание
Fizik_S писал(а): Ср авг 19, 2026 10:40:52 Если не нужна прецизионная точность
Что вы понимаете под "прецизионной точностью" ? Задержки ?
Fizik_S писал(а): Ср авг 19, 2026 13:25:14 Модельку слепил.
У меня 8.6 SP2 не открывает
Вообще не очень понимаю, как Орион - 128 целиком работает. У меня на 50 корпусе уже всё падало. Хотя там соизмеримо. да и небось узел регенерации ОЗУ можно проредить. ВВ55ые убрать, кроме "клавиатурной" и заменить регистрами по "жёстким" адресам.
Интересно еще как видеовывод реализован был, а загрузка ПО через ROM диск ?
(18.27 КБ) 55 скачиваний
Сообщение Fizik_S »
Нужен Proteus именно 8.17 SP5. У них проблема: старые версии не открывают проекты, созданные в более новых версиях. Я пользуюсь этим: https://disk.yandex.ru/d/vuraPCFnQFLrbg (ссылка на мой я-диск)
Ссылки на рабочую схему Орион: http://www.nedopc.org/forum/viewtopic.php?t=23931 (для Протеуса 8.6)
Мои доработки с моими моделями: http://www.nedopc.org/forum/viewtopic.php?t=24258 (Протеус 8.17 ) Доработки продолжаются. Хочу сделать VGA выход в Орион.
Самое смешное, что по логике версия 8.6 SP2 старше, чем 8.17 SP5. Странно как-то. Но начал качать.
Сообщение Fizik_S »
Небольшое обновление библиотек моделей Proteus.
Добавлено:
74ALS21, 74ALS21.DM , 74ALS21.IEC , 74ALS166 , 74ALS166.IEC , 74ALS193 , 74ALS193.IEC , 74ALS241 , 74ALS241.IEC
74AS21, 74AS21.DM, 74AS21.IEC, 74AS241, 74AS8241,IEC
74S241, 74S241.IEC
74F166, 74F166.IEC, 74FI93, 74F193.IEC
74HCT21, 74HCT121.DM, 74HCT21.IEC, 74HCT166, 74HCT166.IEC, 74HCT393, 74HC93, 74HCT93, 74HCT390, 74HCT193
Установка моделей описана в топике
(129.68 КБ) 7 скачиваний
Результаты симуляции:
(50.83 КБ) 3 скачивания
(123.83 КБ) 3 скачивания
DATA.zip
(484.46 КБ) 3 скачивания
Сообщение Halex07 »
Призрачный Суслик писал(а): Ср авг 19, 2026 16:21:51 Самое смешное, что по логике версия 8.6 SP2 старше, чем 8.17 SP5
Что то у Вас со счётом совсем туговато!!! С каких пор 17 стало меньше, чем 6??? Вот если бы стояло через точку 8.1.7 (но такой я не видел), то это была бы версия 8.1 ... 7-й релиз. У Лабцентра так "считается"! Ну и далее по сервис пакам, чем выше SP в одной версии, тем свежее. Так что 8.17 - более поздняя версия чем 8.6.
Думал 8.6 это типа 8.60
