Хитро-умный аккумулятор.
Ремонт портативной техники - телефоны, КПК, навигаторы и типа того.
veigalex
Re: Хитро-умный аккумулятор.
Сообщение veigalex »
[uquote="shura1971",url="/forum/viewtopic.php?p=4431356#p4431356"][uquote="veigalex",url="/forum/viewtopic.php?p=4429740#p4429740"]Я рыскал по интернету, и я подумал, что Windows может читать и управлять батареей Epron... Я пошел на linux и рылся с ACPI.. У меня были эти данные.. Читает из epron.
Изображение[/uquote]
Take the data from this picture. But only at the same time
From the dump (.bin) looking for your picture data....But only in HEX
For example: Voltage: 16.748 V; 2 byte data ;
16.748(dec) = 10BE(hex); in memory: 10 BE ; or BE 10;
look for this data in your dump...
Good luck!!
it's all...
Perhaps your data is somewhere else, on a PC...[/uquote]
I confess that I already converted all this main data into Hexadecimal and tried to look for it in the Eepron file.
I didn't find anything like it.
Reading the Bin file also seems strange, but I tested it with several programs and always the same result.
I'll try again with B2W... I didn't have time yesterday.
I find it difficult for this data to be in the notebook...but there is a lack of knowledge.
I don't know if anyone has mastered this area, but Windows must require a data standard to be able to show information in software (BatteryMon, Sandra, etc.)
The information is somewhere...
shura1971
Сообщение shura1971 »
veigalex, Maybe someone knows the information...
I don't have it. Maybe someone else will tell you.
Пообщаться: https://t.me/Shura197105
МАКС
Спойлерhttps://max.ru/u/f9LHodD0cOJ6gbE_ds1hP6 ... asJV6vUOTE
Мак-Буки/bq20z451
СПРАВКА ПО АКБ https://disk.yandex.ru/d/HExh7zVtUiZ1MA
FX2LP_Bat-Info_READER CP2112_Bat-Info_READER
https://radiokot.ru/forum/viewtopic.php ... 2#p4790272
Wertos
Сообщение Wertos »
[uquote="Vovan_sar",url="/forum/viewtopic.php?p=4331523#p4331523"][uquote="Andrey099",url="/forum/viewtopic.php?p=4331364#p4331364"][uquote="Vovan_sar",url="/forum/viewtopic.php?p=4330440#p4330440"]Если это акб CF-VZSU29(или что-то аналогичное) от защищенного ноута Panasonic
с него(с разъёма) отчеты не получить (((
В контроллере еепромка s24c04, основной чип в самом ноуте.
Снятие дампа с этой памяти ничем не поможет, ну если только времени дофига...
с наскока не получится[/uquote]
в контроллере нет епром. совсем
На последнем фото не читаема надпись на 8-ногой микрушке в правом нижнем углу.
Если она есть, то она отзовется на следующие манипуляции )))
Вот распиновка разъема:
_____TOP_____
|-| |C|D| | | | | |X|+|
У вас же есть CP2112? Демка бешки наверно тоже есть? Подключайтесь к разъёму акб, вибираете в бешке 24С04 и читаете дамп. Контроллер акб должен быть запитан.[/uquote]
Приветствую ! Такой же контроллер... Немножко не понял по распиновке... Там же 8 пинов всего ? Как считать ?
Вначале 2 минуса, а дальше ?
shura1971
Wertos,
А схемы ноута нет?? Все оттуда берется...
Там еще одна фотка есть...
По этой фото - Х отмечен пустой контакт. От этого и двигайтесь.
Чуть повыше посты посмотрите схему - там один контакт это Питание МС памяти
Может у вас так-же. Тестером никто не запрещает пользоваться... :)))
Найдите контакты от МС памяти до разьема.
МАКС
Мак-Буки/bq20z451
Wertos
Сообщение Wertos »
Я нашёл распиновку, но обнаружил что вместо микросхемы с 8 ногами, стоит с 6 ног
3P26
I449
датащита нифига нет ((
(230.68 КБ) 114 скачиваний
shura1971
Wertos,
На фото 8 ног, названия не видно
МАКС
Мак-Буки/bq20z451
Wertos
Сообщение Wertos »
[uquote="shura1971",url="/forum/viewtopic.php?p=4432238#p4432238"]Wertos,
На фото 8 ног, названия не видно[/uquote]
Фото в посте не моё, свое сделаю сегодня. У меня 6 ног, если я не совсем слеп...
ruslsus
Сообщение ruslsus »
Подскажите пож., почему контроллер блокирует батарею после снятия флагов ошибок? BQ20Z70 и BQ29330
(106.59 КБ) 109 скачиваний
(101.52 КБ) 97 скачиваний
Vovan_sar
Сообщение Vovan_sar »
[uquote="ruslsus",url="/forum/viewtopic.php?p=4433597#p4433597"]Подскажите пож., почему контроллер блокирует батарею после снятия флагов ошибок? BQ20Z70 и BQ29330[/uquote]
Опишите порядок своих действий, кратко хотя бы. И приложите отчет по кнопке Info/
ruslsus
Сообщение ruslsus »
Делал по видео из ютуба. Еще вместо перемычки jp1 подключал мелкую лампочку, чтобы контроллер не жег предохранитель.
(95.83 КБ) 120 скачиваний
(254.24 КБ) 107 скачиваний
shura1971
ruslsus,
Насколько видно, вы пользуетесь Be2W. У вас IT не запущен. И Мосфеты закрыты...FetControl = 0000 !!
Нажмите "Open Fet" и кнопку IT
Правда смущает флаг PFIN... Предохранитель целый у вас??
SYS Pres - на "землю".
Подать с "+" сборки на "+" разьема АКБ
В ноут втыкали АКБ?? Работает или нет в ноуте?
Как вариант - отпаять сборку порядком от"+" к "-" и припаять в обратном порядке, при условии, что предохранитель целый.
МАКС
Мак-Буки/bq20z451
Vovan_sar
ruslsus, как правильно подметил shura1971, вам надо убрать флаг PFIN в PFStatus
После чтения дампа, нажимаете кнопку "звездочку" -ClearPFF, можно несколько раз. после проверяете чтением INFO чтобы в PFStatus было ОК
shura1971
Видимо еще не все запомнили, что после :
UNSEAL нужна пауза - 4 с
FullAccess - без паузы
ClearPF - Пауза - 4 с
Можно попользоваться моей прогой, - там все учтено...
:beer:
МАКС
Мак-Буки/bq20z451
Winlin
Сообщение Winlin »
Добрый день. Есть аккумулятор на bq30z55 x550a от Asus
Читался полностью Не жадной.
случайно нажал Write Chip
прервал запись , но теперь чип не читается, напряжение аккум не выдает. Есть ранее считанный bin файл с него, но BEшка прошить его не может-валится с ошибкой. Возможно ли поднять аккумулятор или уже только на запчасти?
файл
https://cloud.mail.ru/public/1yQJ/tPvgY9wxa
Киллер пишет
ERROR: Could not perform SMBus read 0x00
shura1971
Winlin,
Вы из БУТ-ром наверное вышли...
Попробуйте вот отсюда взять инфу, как и что...
https://vlab.su/viewtopic.php?p=821883& ... 70#p821883
И на два поста дальше.
МАКС
Мак-Буки/bq20z451
Winlin
Сообщение Winlin »
на все попытки подать команду ww получаю Write error.
shura1971
Winlin, Через Киллера тоже ошибки валятся при записи блока??
А читать не пробовали блок по ссылке выше?
МАКС
Мак-Буки/bq20z451
Winlin
Сообщение Winlin »
Киллер тоже ошибки записи /чтения выдает
Пробовал обесточить bq30z55 путем последовательного отключения и потом подключения банок. результат нулевой.
shura1971
Winlin, Вы помните, что записали в ЕЕПРОМ??
Зря прервали запись...
МАКС
Мак-Буки/bq20z451
Winlin
Сообщение Winlin »
либо все FF , либо дамп, ранее считанный.
кнопка в BEWork "write chip"
хотел SMBus команду послать , да по запарке не в ту кнопку ткнул.
Вернуться в «Дохлые потаскунчики»
