Инициализация видеоконтроллера MX88V462
taran_ob
Сообщение taran_ob »
Благодаря помощи wss60, есть первые результаты http://radiokot.ru/forum/viewtopic.php? ... 0#p2068630
Разбираюсь с генерацией OSD. Из даташита на MX88V462 http://radiokot.ru/forum/download/file.php?id=186737
128 fixed characters and 64 programmable characters
Display 128 characters in valid display area.  ??????
Composition of a character: 18 x 12 dots
Не могу понять, как в RAM хранятся символы? Как сослаться на символ встроенного шрифта?
Интуитивно представляю FONT TABLE RAM как массив бит 18 строк на (12*(128+64)) столбцов, но не вижу подтверждения в исходнике. Что задает массив m_RamFontTab?
Вот кусок:
На стр 112 даташита:
EXT REG ADRESS_L 0xF2[D5-0] CHAR CODEOF FONT TABLE RAM
EXT REG ADRESS_H 0xF3[D4-0] SCAN LINE OF THE FONT APPOINTED BY REG 0xA0 (0 - 0x11)
EXT REG DATA_L 0xF4[D7-0] DATA FONT TABLE RAM
EXT REG DATA_H 0xF5[D7-0] DATA FONT TABLE RAM
unsigned char m_RamFontTab[]=
	0xFF,0x0F,0xFF,0x0F,0x00,0x0C,0x00,0x0C,0x00,0x0C,0x7F,0x0C,0x7F,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,//LT
	0xFF,0x0F,0xFF,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x0F,0xFF,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//T
	0xFF,0x0F,0xFF,0x0F,0x03,0x00,0x03,0x00,0x03,0x00,0xE3,0x0F,0xE3,0x0F,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,//RT
	0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,//R
	0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0x63,0x00,0xE3,0x0F,0xE3,0x0F,0x03,0x00,0x03,0x00,0x03,0x00,0xFF,0x0F,0xFF,0x0F,//RB
	0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x0F,0xFF,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x0F,0xFF,0x0F, //B
	0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x7F,0x0C,0x7F,0x0C,0x00,0x0C,0x00,0x0C,0x00,0x0C,0xFF,0x0F,0xFF,0x0F,//LB
	0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C,0x60,0x0C//L
#define MXIC_CHAR_COUNT_PER_LINE     16
#define MXIC_CHAR_LINE_COUNT         8
#define OSD_ADDRESS_L        0xF2
#define OSD_ADDRESS_H        0xF3
#define OSD_DATA_L           0xF4
#define OSD_DATA_H           0xF5
unsigned char MXIC_OSDReg_Write(unsigned char m_Target,unsigned int m_Address,unsigned char *m_Data,unsigned int m_Count)
    int i,m_Offset=0;
    int j;
    unsigned char m_Address_H;
    unsigned char m_Address_L;
	MXIC_WriteExternalReg(OSD_RW_CTRL,m_Target|0x80);//Burst Mode Write
	m_Address_H=(unsigned char)(m_Address/0x100);
    m_Address_L=(unsigned char)(m_Address-OSD_ADDRESS_H*0x100);
	MXIC_WriteExternalReg(OSD_ADDRESS_H,m_Address_H);
    MXIC_WriteExternalReg(OSD_ADDRESS_L,m_Address_L);
	switch(m_Target)
        case OSD_CTRL_REG:
            for(i=0;i<m_Count;i++)
                MXIC_WriteExternalReg(OSD_DATA_L,m_Data[i]);
            break;
        case OSD_FONT_RAM:
            for(i=0,m_Offset=0;i<m_Count;i++)
                for(j=0;j<18;j++)
                    MXIC_WriteExternalReg(OSD_DATA_L,m_Data[m_Offset]);
                    MXIC_WriteExternalReg(OSD_DATA_H,m_Data[m_Offset+1]);
                    m_Offset+=2;
            break;
        case OSD_CODE_BUFFER:
            for(i=0,m_Offset=0;i<m_Count;i++,m_Offset+=2)
            break;
        case OSD_ATTR_REG:
            break;
    MXIC_WriteExternalReg(OSD_RW_CTRL,0x04);//Disable OSD Read_Write Mode
    return 1;
unsigned char OSD_AutoLoadRamFont(void)
    return MXIC_OSDReg_Write(OSD_FONT_RAM,0x00,m_RamFontTab,8);
unsigned char MXIC_OSD_ShowText(unsigned char *m_Str,unsigned char m_Count,unsigned char m_RowVal,unsigned char m_ColVal)
    unsigned char m_DisplayBuffer[MXIC_CHAR_COUNT_PER_LINE*2]={' '};
    unsigned char m_AttributeBuffer[MXIC_CHAR_COUNT_PER_LINE*2]={' '};
    int i,j;
    for(i=0,j=0;i<m_Count;j+=2,i++)
         m_DisplayBuffer[j]=ASCII_TO_FONTIndex(m_Str[i]);
         m_DisplayBuffer[j+1]=0x04;
    MXIC_OSDReg_Write(OSD_CODE_BUFFER,(m_RowVal*OSD_COL_COUNT+m_ColVal),m_DisplayBuffer,m_Count);
    return 1;
wss60
Re: Инициализация видеоконтроллера MX88V462
Сообщение wss60 »
Если преобразовать (по алгоритму в коде) массив (m_RamFontTab) в графику то получаются квадратики с полосками, которые можно собрать в рамку любого размера. Похоже это рамка для меню в виде шрифта.
В остальном нужно разбираться…
Если попробовать передать числа от 0..255 – что на экране при этом происходит?
unsigned char i;
for (i=0;i<0xFF;i++)
  MXIC_OSD_ShowText(i, 1,0,0);
  _delay_ms(500);
(862 байт) 1985 скачиваний
taran_ob
Так и понял, что в m_RamFontTab 8 символов. Въехал в структуру OSD_FONT_RAM. А вот как в code buffer передать индекс программного символа не понял.
Сразу не заметил, что размерность адреса коде буфер - 7бит, от туда и "Display 128 characters in valid display area"
Так в том то и дело, что MXIC_OSD_ShowText не работает. Там, кстати, ворнинг при компиляции... makes pointer from integer without a cast ???
А конкретно - не то, что ожидается, символы не перебираются. Видно в рамке три символа, первый периодически меняется с O на X без закономерности, 2 и 3 - набор пикселей - появляются - пропадают. Если применить OSD_ShowText, у нее внутри очистка кодебуфера, то на экране вообще ни чего.
Сразу после включения в кодебуфере есть какой то мусор, фото в теме T112 его демонстрирует. Смущает, что картинка не статична. После очистки и железного ресета - мусор не появляется.
Проблема, мне кажется с передачей массива указателей в функцию MXIC_OSD_ShowText.
На MXIC_OSDReg_SingleWrite(OSD_CODE_BUFFER,0x0000,0x04, ASCII_TO_FONTIndex(0x31));
получаю 1 в верхнем левом углу рамки :)
Что такое 0x04 в MXIC_OSD_ShowText
m_DisplayBuffer[j]=ASCII_TO_FONTIndex(m_Str);
m_DisplayBuffer[j+1]=0x04; //???????????
Вот как организован CODE BUFFER
MXIC_OSDReg_SingleWrite(OSD_CODE_BUFFER,i,0x04, ASCII_TO_FONTIndex(i));
Заменил фото
(63.72 КБ) 1980 скачиваний
128 : 255
(38.01 КБ) 1953 скачивания
taran_ob
Появилось время закончить мониторчик.
МК ATMEGA8L, внутренний генератор 8МГЦ, 3 кнопки, программный I2C.
Корпус отфрезеровал из 10мм оргстекла.
Дорисовал крестик, с возможностью передвижения и изменения цвета, а также добавил возможность смены формата PAL 4:3/16:9 .
Полноценное меню кодить лень.
Исходники прилагаю.
Забыл про питание сказать.
I,A U,V
0.16 3.3 цифра
0.1 5 аналог
0.21 5 LED подсветка
MX88V462.rar
Исходник
(87.6 КБ) 361 скачивание
wss60
Сообщение wss60 »
Отлично! :)
Не понятно только что в массиве OSD_CHAR_TAB зашифровано?
taran_ob
Это массив из 128 кодов символов, которые могут в статике отображаться в видимой области(в окне/окнах) экрана, в данном случае крестик. 128 - максимум.
Адреса вшитых символов можно вычислить по фото выше, адреса пользовательских от 128-192.
пс была мысль добавить к экрану USART для проверки связи с различными устройствами, но 128 символов показалось маловато, может попробую в динамике выводить инфу...
wss60
Сообщение wss60 »
Теперь разобрался :)
Попробую применить в t112…
Вернуться в «Периферия»
