Форум РадиоКот • Просмотр темы - Bootloader PIC18F25K80
Текущее время: Ср фев 18, 2026 17:17:33
Начать новую тему Ответить на тему  [ Сообщений: 35 ]  1,
 Заголовок сообщения: Bootloader PIC18F25K80
СообщениеДобавлено: Ср авг 17, 2016 14:24:53
Решил воспользоваться микрочиповским бутлодером AN1310 вроде все сделал как в даташите: настроил конфигурационные биты:
Подкорректировал bootconfig.inc в соответствии со схемой и камнем (использую UART2):
Код:
; Copyright (c) 2002-2011,  Microchip Technology Inc.
; Microchip licenses this software to you solely for use with Microchip
; products.  The software is owned by Microchip and its licensors, and
; is protected under applicable copyright laws.  All rights reserved.
; SOFTWARE IS PROVIDED "AS IS."  MICROCHIP EXPRESSLY DISCLAIMS ANY
; WARRANTY OF ANY KIND, WHETHER EXPRESS OR IMPLIED, INCLUDING BUT
; NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS
; FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT.  IN NO EVENT SHALL
; MICROCHIP BE LIABLE FOR ANY INCIDENTAL, SPECIAL, INDIRECT OR
; CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, HARM TO YOUR
; EQUIPMENT, COST OF PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY
; OR SERVICES, ANY CLAIMS BY THIRD PARTIES (INCLUDING BUT NOT LIMITED
; TO ANY DEFENSE THEREOF), ANY CLAIMS FOR INDEMNITY OR CONTRIBUTION,
; OR OTHER SIMILAR COSTS.
; To the fullest extent allowed by law, Microchip and its licensors
; liability shall not exceed the amount of fees, if any, that you
; have paid directly to Microchip to use this software.
; MICROCHIP PROVIDES THIS SOFTWARE CONDITIONALLY UPON YOUR ACCEPTANCE
; OF THESE TERMS.
;#define TBLWT_BUG               ; Enable this to work around timing bug found in some PIC18Fxx20's
;#define INVERT_UART             ; If you don't have an RS232 transceiver, you might want this option
#define USE_MAX_INTOSC          ; Sets OSCCON<IRCF2:IRCF0> for maximum INTOSC frequency (8MHz)
#define USE_PLL                 ; Sets OSCTUNE.PLLEN bit at start up for frequency multiplication.
;#define PICDEM_LCD2             ; RB0 = 1 required to enable MAX3221 TX output on PICDEM LCD 2 demo board
#define USE_SOFTBOOTWP          ; enable software boot block write protection
;#define USE_SOFTCONFIGWP        ; enable software config words write protection
; Autobaud will be used by default. To save code space or to force a specific baud rate to be used,
; you can optionally define a BAUDRG value instead. Most PIC18's support BRG16 mode and use the
; following equation:
;       BAUDRG = Fosc / (4 * Baud Rate) - 1
; Old PIC18's without BRG16 mode need this equation instead:
;       BAUDRG = Fosc / (16 * Baud Rate) - 1
; Examples:
;#define BAUDRG .51              ; 19.2Kbps from 4MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .103             ; 115.2Kbps from 48MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .85              ; 115.2Kbps from 40MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .68              ; 115.2Kbps from 32MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .16              ; 115.2Kbps from 8MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .11              ; 1Mbps from 48MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .9               ; 1Mbps from 40MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .4               ; 2Mbps from 40MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .3               ; 3Mbps from 48MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .12              ; 19.2Kbps from 4MHz, 115.2Kbps from 24MHz (BRG16 = 0, BRGH = 1)
;#define BAUDRG .10              ; 115.2Kbps from 19.6608MHz (BRG16 = 0, BRGH = 1)
; Bootloader must start at the beginning of a FLASH Erase Block. If unspecified,
; bootloader will automatically be located at the end of program memory address space.
#define BOOTLOADER_ADDRESS   0  ; bootloader at beginning, application start/ISR vectors require remapping
;#define BOOTLOADER_ADDRESS   END_FLASH - (ERASE_FLASH_BLOCKSIZE * 20)  ; useful for running under debugger (debug executive wants to reside at the end of memory space too)
;#define BOOTLOADER_ADDRESS  (END_FLASH - ERASE_FLASH_BLOCKSIZE) ; use on J parts to locate inside flash config erase block
#ifdef BOOTLOADER_ADDRESS
  #if BOOTLOADER_ADDRESS == 0
    ; For Bootloader located at program memory address 0, the application firmware must
    ; provide remapped reset and interrupt vectors outside of the Boot Block. The following
    ; #defines tell the bootloader firmware where application entry points are to be expected:
    #define AppVector           0x400   ; application start up code should be located here.
    #define AppHighIntVector    0x408   ; application high priority interrupt should be located here
    #define AppLowIntVector     0x418   ; application low priority interrupt should be located here
  #endif
#endif
; Define UART pins and registers.
; Modify the following lines if you want to use a different UART module.
; Note: If your UART's RX pin happens to be multiplexed with analog ANx input
;   functionality, you may need to edit the "preprocess.inc" DigitalInput
;   macro. Code there needs to enable the digital input buffer (refer to
;   ADC chapter of your device's datasheet).
#define UARTNUM 2
#if UARTNUM == 1
    #define UxSPBRG         SPBRG
    #define UxSPBRGH        SPBRGH
    #define UxRCSTA         RCSTA
    #define UxTXSTA         TXSTA
    #define UxRCREG         RCREG
    #define UxTXREG         TXREG
    #define UxPIR           PIR1
    #define UxRCIF          RCIF
    #define UxTXIF          TXIF
    #define UxBAUDCON       BAUDCON
;    #define RXPORT         PORTC   ; RX on RC7 is used by default for most PIC18's.
;    #define RXPIN          .7
;    #define RXPORT          PORTB   ; PIC18F14K50: RX on RB5/AN11
;    #define RXPIN           .5
;    #define RXANSEL         ANSELH  ; RX/AN11 multiplexed -- must enable digital input buffer
;    #define RXAN            .3      ; ANSELH<3> controls AN11 digital input buffer
#endif
#if UARTNUM == 2
    #define UxSPBRG         SPBRG2
    #define UxSPBRGH        SPBRGH2
    #define UxRCSTA         RCSTA2
    #define UxTXSTA         TXSTA2
    #define UxRCREG         RCREG2
    #define UxTXREG         TXREG2
    #define UxPIR           PIR3
    #define UxRCIF          RC2IF
    #define UxTXIF          TX2IF
    #define UxBAUDCON       BAUDCON2
;    #define RXPORT          PORTG   ; RG2 is default RX2 pin for some high pin count PIC18's.
;    #define RXPIN           .2
;    #define RXPORT          PORTD   ; RX2 pin PPS'ed to RD4/RP21 on PIC18F46J11 for example.
;    #define RXPIN           .4
;    #define RXANSEL         ANSELH  ; On PICs where RX is multiplexed with ANx analog inputs,
;    #define RXAN            .3      ; the digital input buffer needs to be enabled via ANSELx SFRs
    ; devices that use PPS to remap UART2 pins will need these lines defined:
;    #define PPS_UTX         .5      ; PPS code for TX2/CK2 output function
;    #define PPS_UTX_PIN     RPOR23  ; UART TX assigned to RP23 pin
;    #define PPS_URX_PIN     .21     ; UART RX assigned to RP21 pin
;    #define PPS_URX         RPINR16 ; PPS register for RX2/CK2 input function
#endif
; If you get linker errors complaining "can not fit the absolute section," you might want to
; increase BOOTLOADERSIZE below or set the BOOTLOADER_ADDRESS above to a smaller address number.
; Because we need to know the total size of the bootloader before the assembler has finished
; compiling the source code, we have to estimate the final bootloader size and provide it
; here as BOOTLOADERSIZE. This number is in bytes (twice the instruction word count).
; If you see the bootloader is reserving more FLASH memory than it really needs (you'll
; see a bunch of FFFF/NOP instructions at the end of the bootloader memory region),
; you can try reducing BOOTLOADERSIZE.
#define BOOTLOADERSIZE  .708
#define MAJOR_VERSION   .1              ; Bootloader Firmware Version
#define MINOR_VERSION   .5
Скомпиллировал, прошил, подключаю к компу через usb-uart , а программа пишет: Bootloader not found.
Что я делаю не так?
 Заголовок сообщения: Re: Bootloader PIC18F25K80
СообщениеДобавлено: Ср авг 17, 2016 16:16:51
Рейтинг сообщений: 81
Когда-то тоже возился с этим загрузчиком. В итоге для отладки пришлось написать прогу-терминал под Windows.
А точно USART2 правильно работает? Я бы сначала на тестовой прошивке попробовал бы связаться, а потом уже с загруэчиком разбираться...
СообщениеДобавлено: Ср авг 17, 2016 17:15:52
В смысле? Он может работать неправильно? Непонятен смысл написания прошивки для проверки UART2.
Могу написать простенькую программку на си, которая будет возвращать то что приняла. Уверен на 99,999% что она будет работать.
СообщениеДобавлено: Ср авг 17, 2016 20:05:11
Вот когда будет 100% тогда можно браться и за загрузчик :tea:
СообщениеДобавлено: Чт авг 18, 2016 07:37:46
Проверил, работает 100%.
А вот загрузчик - никак.
СообщениеДобавлено: Чт авг 18, 2016 08:11:00
На других камнях с этим загрузчиком работали? Как вход в пп загрузчика осуществляете?
СообщениеДобавлено: Чт авг 18, 2016 08:35:38
На других МК - не пробовал.
Вход осуществляется установкой логического нуля на RX при старте МК. Делаю это с помощью утилиты входящей в комплект AN1310 (Нужно нажать соответствующую кнопку).
Может посоветует кто-нибудь проверенный бутлоадер для вышеуказанного камня?
В MPLAB Code Generator есть библиотека загрузчика, попробовал её использовать, но она не компиллируется, вылетает куча ошибок. Да и непонятно как вообще им пользоваться на стороне ПК?
СообщениеДобавлено: Чт авг 18, 2016 08:50:08
Так загрузчик и не должен работать!!!
bootconfig.inc - см. настройку USART, генератора МК...
СообщениеДобавлено: Чт авг 18, 2016 08:58:47
Я не понимаю, пожалуйста, объясните на что именно смотреть?
СообщениеДобавлено: Чт авг 18, 2016 10:10:36
Как-то странно звучит ваш ответ, т.к. вы уже тестом проверили работу с USART - значит понимаете что это за зверь, а вот в загрузчике "не обратили внимание" на BAUDRG и остальные настройки USART и не только...
СообщениеДобавлено: Чт авг 18, 2016 10:26:56
Я же попросил
Если Вы не можете дать однозначный ответ, постараюсь угадать что-же Вы имели в виду.
Возможно Вас смутило что все строки с указанием BAUDRG закомментированы?
СообщениеДобавлено: Чт авг 18, 2016 10:51:38
Я вот как-то не могу вас понять: с одной стороны вы написали тестовую прошивку, в которой настраивали USART, указывая скорость и т.д., а в загрузчике не убрали комментарий с нужной строки! Так же не сделали настройку порта на USART2...
СообщениеДобавлено: Чт авг 18, 2016 10:58:35
Там же в комментарии написано:
По умолчанию работает автоопределение скорости, но если хотите - можете настроить на определенную скорость. Для этого нужно указать BAUDRG.
Вот же она:
Dmitry888 писал(а):
#define UARTNUM 2
СообщениеДобавлено: Чт авг 18, 2016 11:17:57
Сначала нужно сделать на фиксированной скорости! И на всякий случай, для отладки, я бы поставил кварц
Ноги порта для USART2 правильно выставлены? Все "лишнее" отключено? Прерывания?
СообщениеДобавлено: Чт авг 18, 2016 11:39:07
Утром я проверил на тестовой прошивке , работает на фиксированной с внутренним кварцем. Попробовал в bootconfig.inc указать
Код:
#define BAUDRG .207
По моим подсчётам это 9600 при 8MHz внутреннего генератора - так не работает.
Для внешнего кварца настроек в bootconfig.inc не предусмотрено, а в ассемблере я не силён.
СообщениеДобавлено: Чт авг 18, 2016 12:02:02
Код:
#define BAUDRG .207
это для каких значений SYNC, BRGH и BRG16?
СообщениеДобавлено: Чт авг 18, 2016 12:05:01
Как-то не клеится с вашим первым сообщением...
СообщениеДобавлено: Чт авг 18, 2016 12:19:19
Ошибочка, при
Код:
, по коду это: OSCCON<IRCF2:IRCF0> 111 - частота внутреннего генератора будет 16MHz.
Переделал так:
Код:
#define BAUDRG .103      ; 38.4 16MHz
Один хрен не работает.
SYNC = 0 (Asynchronous mode)
С остальными я не разобрался. По коду мне непонятно. Привожу тут исходники, может кто подскажет:
bootloader.asm
Код:
; OF THESE TERMS.
; Author        Date        Comment
; E. Schlunder  07/20/2010  Software Boot Block Write Protect code
;                           improved. 96KB memory size devices should
;                           work now.
; E. Schlunder  02/26/2010  Changed order of start up code so that PLLEN
;                           is enabled before we wait for RXD IDLE state.
;                           This improves connection time/reliablity on
;                           J devices.
; E. Schlunder  08/28/2009  Software Boot Block Write Protect option.
; E. Schlunder  07/09/2009  Brought back support for bootloader at
;                           address 0 for hardware boot block write
;                           protection on certain devices.
; E. Schlunder  05/07/2009  Replaced the simple checksum with a
;                           16-bit CCIT CRC checksum.
;                           Added ReadFlashCrc command for quick verify.
; E. Schlunder  05/02/2009  Improved autobaud code to handle 1Mbps
;                           and BRG16/BRGH.
; E. Schlunder  05/01/2009  Added support for DEVICES.INC generated
;                           from Device Database tool.
; E. Schlunder  04/29/2009  Added support for locating the bootloader
;                           at the end of program memory instead of
;                           the beginning. This will eventually let us
;                           use normal application firmware code without
;                           linker script modifications.
; E. Schlunder  04/26/2009  Optimized Config Write routine to avoid
;                           re-writing values matching existing config
;                           data.
; E. Schlunder  04/24/2009  Optimized EEPROM Write routine a little bit.
;                           Optimized FLASH Read routine to stream data
;                           directly from FLASH instead of using RAM
;                           buffer.
;                           Added option for faster STX acknowledgements.
; E. Schlunder  04/17/2009  Added code to enter bootloader mode if
;                           a serial break condition is detected on
;                           RXD as we come out of reset. This will
;                           make it possible to re-enter the bootloader
;                           even if the application firmware is missing
;                           code to re-enter bootloader mode.
;                           This also simplies the bootloader, as
;                           we do not need a boot flag any more.
; E. Schlunder  04/15/2009  Removed EOF command 8, new PC software
;                           does 64 byte block aligned writes at all
;                           times on J device, so there is no need for
;                           this command going forward.
; E. Schlunder  04/14/2009  Added a BootloadMode vector back at the
;                           beginning of program memory so that user
;                           applications can jump back into the boot
;                           loader without having to erase the boot flag.
; E. Schlunder  04/08/2009  Now initializes FSR2 to 0 so that the code
;                           can operate under Extended Instruction Set
;                           mode if necessary.
; E. Schlunder  04/01/2009  Fixed bug in J_FLASH erase address increment.
;                           Added support for enabling PLL.
;                           Added support for inverted UART signaling.
;                           Added support for fixed (non-autobaud)
;                           operation, helps with debugging code under ICD.
; E. Schlunder  03/25/2009  No longer attempts to use EEADRH on PIC18F4321.
; UART Bootloader for PIC18F by Ross Fosler
; 09/01/2006  Modified to support PIC18xxJxx & 160k PIC18Fxxx Flash Devices
; 03/01/2002 ... First full implementation
; 03/07/2002 Changed entry method to use last byte of EEDATA.
;            Also removed all possible infinite loops w/ clrwdt.
; 03/07/2002 Added code for direct boot entry. I.E. boot vector.
; 03/09/2002 Changed the general packet format, removed the LEN field.
; 03/09/2002 Modified the erase command to do multiple row erase.
; 03/12/2002 Fixed write problem to CONFIG area. Write was offset by a byte.
; 03/15/2002 Added work around for 18F8720 tblwt*+ problem.
; 03/20/2002 Modified receive & parse engine to vector to autobaud on a checksum
;            error since a chechsum error could likely be a communications problem.
; 03/22/2002 Removed clrwdt from the startup. This instruction affects the TO and
;            PD flags. Removing this instruction should have no affect on code
;       operation since the wdt is cleared on a reset and boot entry is always
;       on a reset.
; 03/22/2002    Modified the protocol to incorporate the autobaud as part of the
;       first received <STX>. Doing this improves robustness by allowing
;       re-sync under any condition. Previously it was possible to enter a
;       state where only a hard reset would allow re-syncing.
; 03/27/2002    Removed the boot vector and related code. This could lead to customer
;       issues. There is a very minute probability that errent code execution
;       could jump into the boot area and cause artificial boot entry.
#include <p18cxxx.inc>
#include "devices.inc"
#include "bootconfig.inc"
#include "preprocess.inc"
#define STX             0x0F
#define ETX             0x04
#define DLE             0x05
#define NTX             0xFF
; RAM Address Map
CRCL                equ 0x00
CRCH                equ 0x01
RXDATA              equ 0x02
TXDATA              equ 0x03
; Framed Packet Format
; <STX>[<COMMAND><ADDRL><ADDRH><ADDRU><0x00><DATALEN><...DATA...>]<CRCL><CRCH><ETX>
COMMAND             equ 0x05        ; receive buffer
ADDRESS_L           equ 0x06
ADDRESS_H           equ 0x07
ADDRESS_U           equ 0x08
ADDRESS_X           equ 0x09
DATA_COUNTL         equ 0x0A
PACKET_DATA         equ 0x0B
DATA_COUNTH         equ 0x0B        ; only for certain commands
    errorlevel -311                 ; don't warn on HIGH() operator values >16-bits
#ifdef USE_SOFTBOOTWP
  #ifndef SOFTWP
    #define SOFTWP
  #endif
#endif
#ifdef USE_SOFTCONFIGWP
  #ifdef CONFIG_AS_FLASH
    #ifndef SOFTWP
      #define SOFTWP
    #endif
  #endif
#endif
#ifndef AppVector
    ; The application startup GOTO instruction will be written just before the Boot Block,
    ; courtesy of the host PC bootloader application.
    #define AppVector (BootloaderStart-.4)
#endif
#if BOOTLOADER_ADDRESS != 0
    ORG     0
    ; The following GOTO is not strictly necessary, but may startup faster
    ; for large microcontrollers running at extremely slow clock speeds.
    ;goto    BootloaderBreakCheck
    ORG     BOOTLOADER_ADDRESS
BootloaderStart:
    bra     BootloadMode
; Determine if the application is supposed to be started or if we should
; go into bootloader mode.
; If RX pin is in BREAK state when we come out of MCLR reset, immediately
; enter bootloader mode, even if there exists some application firmware in
; program memory.
BootloaderBreakCheck:
    DigitalInput                ; set RX pin as digital input on certain parts
#ifdef INVERT_UART
    btfss   RXPORT, RXPIN
GotoAppVector:
    goto    AppVector           ; no BREAK state, attempt to start application
#else
    btfsc   RXPORT, RXPIN
GotoAppVector:
#endif
BootloadMode:
#else ; BOOTLOADER_ADDRESS == 0 ****************************************************************
    ORG     0
BootloaderStart:
    movlw   low(AppVector)      ; load address of application reset vector
    bra     BootloaderBreakCheck
   ORG       0x0008
HighPriorityInterruptVector:
   goto    AppHighIntVector    ; Re-map Interrupt vector
#ifdef INVERT_UART
    btfsc   RXPORT, RXPIN
    bra     BootloadMode
#else
    btfss   RXPORT, RXPIN
    bra     BootloadMode
#endif
CheckAppVector:
    ; Read instruction at the application reset vector location.
    ; If we read 0xFFFF, assume that the application firmware has
    ; not been programmed yet, so don't try going into application mode.
    movwf   TBLPTRL
    movlw   high(AppVector)
    movwf   TBLPTRH
    bra     CheckAppVector2
   ORG       0x0018
LowPriorityInterruptVector:
   goto    AppLowIntVector     ; Re-map Interrupt vector
CheckAppVector2:
    movlw   upper(AppVector)
    movwf   TBLPTRU
    tblrd   *+                  ; read instruction from program memory
    incfsz  TABLAT, W           ; if the lower byte != 0xFF,
GotoAppVector:
    goto    AppVector           ; run application.
    incfsz  TABLAT, W           ; if the lower byte == 0xFF but upper byte != 0xFF,
    bra     GotoAppVector       ; run application.
    ; otherwise, assume application firmware is not present because we read a NOP (0xFFFF).
    ; fall through to bootloader mode...
BootloadMode:
#endif ; end BOOTLOADER_ADDRESS == 0 ******************************************
    lfsr    FSR2, 0             ; for compatibility with Extended Instructions mode.
#ifdef USE_MAX_INTOSC
    movlw   b'01110000'         ; set INTOSC to maximum speed (usually 8MHz)
    iorwf   OSCCON, f
#endif
#ifdef USE_PLL
    #ifdef PLLEN
        #ifdef OSCTUNE
            bsf     OSCTUNE, PLLEN      ; enable PLL for faster internal clock
        #else
            ; 18F8680, 18F8585, 18F6680, and 18F6585 doesn't have OSCTUNE register.
            ; Instead, PLLEN bit is in OSCCON.
            bsf     OSCCON, PLLEN      ; enable PLL for faster internal clock
        #endif
    #else
        #ifdef SPLLEN
            bsf     OSCTUNE, SPLLEN     ; PIC18F14K50 has SPLLEN at bit 6
        #endif
    #endif
#endif
#ifdef INVERT_UART
    btfsc   RXPORT, RXPIN       ; wait for RX pin to go IDLE
    bra     $-2
#else
    btfss   RXPORT, RXPIN       ; wait for RX pin to go IDLE
    bra     $-2
#endif
#ifdef PPS_UTX_PIN
    banksel PPSCON
    ; unlock PPS registers
    movlw   0x55
    movwf   EECON2, ACCESS
    movlw   0xAA
    bcf     PPSCON, IOLOCK, BANKED
    ; assign UART RX/TX to PPS remappable pins
    movlw   PPS_UTX
    movwf   PPS_UTX_PIN, BANKED
    movlw   PPS_URX_PIN
    movwf   PPS_URX, BANKED
    ; lock PPS registers from inadvertent changes
    movlw   0x55
    movlw   0xAA
    bsf     PPSCON, IOLOCK, BANKED
    movlb   0x0F
#endif
    movlw   b'10010000'         ; Setup UART
    movwf   UxRCSTA
    movlw   b'00100110'         ; BRGH = 1, TXEN = 1
    movwf   UxTXSTA
#ifdef INVERT_UART
    bsf     UxBAUDCON, RXDTP
    bsf     UxBAUDCON, TXCKP
#endif
#ifdef BRG16
    bsf     UxBAUDCON, BRG16
    movlw   b'00000010'         ; 1:8 prescaler - no division required later (but no rounding possible)
#else
    movlw   b'00000011'         ; 1:16 prescaler - thus we only have to divide by 2 later on.
#endif
    movwf   T0CON
#ifdef PICDEM_LCD2
    bsf     LATB, LATB0         ; PICDEM LCD 2 demoboard requires RB0 high to enable MAX3221 TX output to PC.
    bcf     TRISB, TRISB0
#endif
#ifdef USE_AUTOBAUD
DoAutoBaud:
; ___    __________            ________
;    \__/          \__________/
;       |-------- p ----------|
;   p = The number of instructions between the first and last
;           rising edge of the RS232 control sequence 0x0F. Other
;       possible control sequences are 0x01, 0x03, 0x07, 0x1F,
;       0x3F, 0x7F.
;   SPBRG = (p / 32) - 1    BRGH = 1, BRG16 = 0
;   SPBRG = (p / 8) - 1     BRGH = 1, BRG16 = 1
    bcf     UxRCSTA, CREN       ; Stop receiving
    movf    UxRCREG, W          ; Empty the buffer
    movf    UxRCREG, W
RetryAutoBaud:
    clrf    TMR0H               ; reset timer count value
    clrf    TMR0L
    bcf     INTCON, TMR0IF
    rcall   WaitForRise         ; wait for a start bit to pass by
    bsf     T0CON, TMR0ON       ; start timer counting for entire D7..D0 data bit period.
    rcall   WaitForRise         ; wait for stop bit
    bcf     T0CON, TMR0ON       ; stop the timer from counting further.
    btfsc   INTCON, TMR0IF      ; if TMR0 overflowed, we did not get a good baud capture
    bra     RetryAutoBaud       ; try again
    #ifdef BRG16
    ; save new baud rate generator value
    movff   TMR0L, UxSPBRG      ; warning: must read TMR0L before TMR0H holds real data
    movff   TMR0H, UxSPBRGH
    #else
    ; TMR0H:TMR0L holds (p / 16).
    rrcf    TMR0H, w            ; divide by 2
    rrcf    UxSPBRG, F
    btfss   STATUS, C           ; rounding
    decf    UxSPBRG, F
    #endif
    bsf     UxRCSTA, CREN       ; start receiving
WaitForHostCommand:
    rcall   ReadHostByte        ; get start of transmission <STX>
    xorlw   STX
    bnz     DoAutoBaud          ; got something unexpected, perform autobaud
#else ; not using autobaud
    movlw   low(BAUDRG)         ; set fixed baud rate generator value
    movwf   UxSPBRG
    #ifdef UxSPBRGH
        #if high(BAUDRG) != 0
    movlw   high(BAUDRG)
    movwf   UxSPBRGH
        #endif
    #endif
DoAutoBaud:
WaitForHostCommand:
    xorlw   STX
    bnz     WaitForHostCommand  ; got something unexpected, keep waiting for <STX>
#endif ; end #ifdef USE_AUTOBAUD
; Read and parse packet data.
StartOfLine:
    movlw   STX                     ; send back start of response
    rcall   SendHostByte
    lfsr    FSR0, COMMAND-1         ; Point to the buffer
ReceiveDataLoop:
    rcall   ReadHostByte            ; Get the data
    xorlw   STX                     ; Check for an unexpected STX
    bz      StartOfLine             ; unexpected STX: abort packet and start over.
NoSTX:
    movf    RXDATA, W
    xorlw   ETX                     ; Check for a ETX
    bz      VerifyPacketCRC         ; Yes, verify CRC
NoETX:
    movf    RXDATA, W
    xorlw   DLE                     ; Check for a DLE
    bnz     AppendDataBuffer
    rcall   ReadHostByte            ; DLE received, get the next byte and store it
AppendDataBuffer:
    movff   RXDATA, PREINC0         ; store the data to the buffer
    bra     ReceiveDataLoop
VerifyPacketCRC:
    lfsr    FSR1, COMMAND
    clrf    CRCL
    clrf    CRCH
    movff   POSTDEC0, PRODH         ; Save host packet's CRCH to PRODH for later comparison
                                    ; CRCL is now available as INDF0
VerifyPacketCrcLoop:
    movf    POSTINC1, w
    rcall   AddCrc                  ; add new data to the CRC
    movf    FSR1H, w
    cpfseq  FSR0H
    bra     VerifyPacketCrcLoop     ; we aren't at the end of the received data yet, loop
    movf    FSR1L, w
    cpfseq  FSR0L
    movf    CRCH, w
    cpfseq  PRODH
    bra     DoAutoBaud              ; invalid CRC, reset baud rate generator to re-sync with host
    movf    CRCL, w
    cpfseq  INDF0
; Pre-setup, common to all commands.
    clrf    CRCL
    clrf    CRCH
    movf    ADDRESS_L, W            ; Set all possible pointers
    movwf   TBLPTRL
#ifdef EEADR
    movwf   EEADR
#endif
    movf    ADDRESS_H, W
    movwf   TBLPTRH
#ifdef EEADRH
    movwf   EEADRH
#endif
    movff   ADDRESS_U, TBLPTRU
    lfsr    FSR0, PACKET_DATA
; Test the command field and sub-command.
CheckCommand:
    movlw   .10
    cpfslt  COMMAND
    bra     DoAutoBaud          ; invalid command - reset baud generator to re-sync with host
    ; This jump table must exist entirely within one 256 byte block of program memory.
#if ($ & 0xFF) > (0xFF - .24)
    ; Too close to the end of a 256 byte boundary, push address forward to get code
    ; into the next 256 byte block.
    messg   "Wasting some code space to ensure jump table is aligned."
    ORG     $+(0x100 - ($ & 0xFF))
#endif
JUMPTABLE_BEGIN:
    movf    PCL, w              ; 0 do a read of PCL to set PCLATU:PCLATH to current program counter.
    rlncf   COMMAND, W          ; 2 multiply COMMAND by 2 (each BRA instruction takes 2 bytes on PIC18)
    addwf   PCL, F              ; 4 Jump in command jump table based on COMMAND from host
    bra     BootloaderInfo      ; 6 00h
    bra     ReadFlash           ; 8 01h
    bra     VerifyFlash         ; 10 02h
    bra     EraseFlash          ; 12 03h
    bra     WriteFlash          ; 14 04h
    bra     ReadEeprom          ; 16 05h
    bra     WriteEeprom         ; 18 06h
    bra     WriteConfig         ; 20 07h
    bra     GotoAppVector       ; 22 08h
    reset                       ; 24 09h
#if (JUMPTABLE_BEGIN & 0xFF) > ($ & 0xFF)
    error "Jump table is not aligned to fit within a single 256 byte address range."
#endif
#ifdef INVERT_UART
WaitForRise:
    clrwdt
WaitForRiseLoop:
    return                  ; abort
    btfss   RXPORT, RXPIN   ; Wait for a falling edge
    bra     WaitForRiseLoop
WtSR:
    btfsc   RXPORT, RXPIN   ; Wait for starting edge
    bra     WtSR
    return
#else ; not inverted UART pins
WaitForRise:
    clrwdt
WaitForRiseLoop
    return                  ; abort
    btfsc   RXPORT, RXPIN   ; Wait for a falling edge
    bra     WaitForRiseLoop
WtSR:
    btfss   RXPORT, RXPIN   ; Wait for rising edge
    bra     WtSR
    return
#endif ; end #ifdef INVERT_UART
; 16-bit CCITT CRC
; Adds WREG byte to the CRC checksum CRCH:CRCL. WREG destroyed on return.
AddCrc:                           ; Init: CRCH = HHHH hhhh, CRCL = LLLL llll
    xorwf   CRCH, w               ; Pre:  HHHH hhhh     WREG =      IIII iiii
    movff   CRCL, CRCH            ; Pre:  LLLL llll     CRCH =      LLLL llll
    movwf   CRCL                  ; Pre:  IIII iiii     CRCL =      IIII iiii
    swapf   WREG                  ; Pre:  IIII iiii     WREG =      iiii IIII
    andlw   0x0F                  ; Pre:  iiii IIII     WREG =      0000 IIII
    xorwf   CRCL, f               ; Pre:  IIII iiii     CRCL =      IIII jjjj
    swapf   CRCL, w               ; Pre:  IIII jjjj     WREG =      jjjj IIII
    andlw   0xF0                  ; Pre:  jjjj IIII     WREG =      jjjj 0000
    xorwf   CRCH, f               ; Pre:  LLLL llll     CRCH =      MMMM llll
    rlncf   WREG, w               ; Pre:  jjjj IIII     WREG =      jjjI IIIj
    xorwf   CRCH, f               ; Pre:  MMMM llll     CRCH =      XXXN mmmm
    andlw   b'11100000'           ; Pre:  jjjI IIIj     WREG =      jjj0 0000
    xorwf   CRCH, f               ; Pre:  jjj0 0000     CRCH =      MMMN mmmm
    xorwf   CRCL, f               ; Pre:  MMMN mmmm     CRCL =      JJJI jjjj
    return
; Commands
; Provides information about the Bootloader to the host PC software.
BootInfoBlock:
    db      low(BOOTBLOCKSIZE), high(BOOTBLOCKSIZE)
    db      MAJOR_VERSION, MINOR_VERSION
    db      0xFF, 0x84             ; command mask : family id
    db      low(BootloaderStart), high(BootloaderStart)
    db      upper(BootloaderStart), 0
BootInfoBlockEnd:
; In:   <STX>[<0x00>]<CRCL><CRCH><ETX>
; Out:  <STX><BOOTBYTESL><BOOTBYTESH><VERL><VERH><STARTBOOTL><STARTBOOTH><STARTBOOTU><0x00><CRCL><CRCH><ETX>
BootloaderInfo:
    movlw   low(BootInfoBlock)
    movwf   TBLPTRL
    movlw   high(BootInfoBlock)
    movwf   TBLPTRH
    movlw   upper(BootInfoBlock)
    movwf   TBLPTRU
    movlw   (BootInfoBlockEnd - BootInfoBlock)
    movwf   DATA_COUNTL
    clrf    DATA_COUNTH
    ;; fall through to ReadFlash code -- send Bootloader Information Block from FLASH.
; In:   <STX>[<0x01><ADDRL><ADDRH><ADDRU><0x00><BYTESL><BYTESH>]<CRCL><CRCH><ETX>
; Out:  <STX>[<DATA>...]<CRCL><CRCH><ETX>
ReadFlash:
    tblrd   *+                  ; read from FLASH memory into TABLAT
    movf    TABLAT, w
    rcall   SendEscapeByte
    rcall   AddCrc
    decf    DATA_COUNTL, f      ; decrement counter
    movlw   0
    subwfb  DATA_COUNTH, f
    movf    DATA_COUNTL, w      ; DATA_COUNTH:DATA_COUNTH == 0?
    iorwf   DATA_COUNTH, w
    bnz     ReadFlash           ; no, loop
    bra     SendChecksum        ; yes, send end of packet
; In:   <STX>[<0x02><ADDRL><ADDRH><ADDRU><0x00><BLOCKSL><BLOCKSH>]<CRCL><CRCH><ETX>
; Out:  <STX>[<CRCL1><CRCH1>...<CRCLn><CRCHn>]<ETX>
VerifyFlash:
    tblrd   *+
    movf    TABLAT, w
    rcall   AddCrc
    movf    TBLPTRL, w          ; have we crossed into the next block?
#if ERASE_FLASH_BLOCKSIZE > .255
    bnz     VerifyFlash
    movf    TBLPTRH, w
    andlw   high(ERASE_FLASH_BLOCKSIZE-1)
#else
    andlw   (ERASE_FLASH_BLOCKSIZE-1)
#endif
    bnz     VerifyFlash
    movf    CRCL, w
    call    SendEscapeByte
    movf    CRCH, w
    call    SendEscapeByte
    movlw   0
    bnz     VerifyFlash         ; no, loop
    bra     SendETX             ; yes, send end of packet
#ifdef SOFTWP
    reset                       ; this code -should- never be executed, but
    reset                       ; just in case of errant execution or buggy
    reset                       ; firmware, these reset instructions may protect
    reset                       ; against accidental erases.
#endif
; In:   <STX>[<0x03><ADDRL><ADDRH><ADDRU><0x00><PAGESL>]<CRCL><CRCH><ETX>
; Out:  <STX>[<0x03>]<CRCL><CRCH><ETX>
EraseFlash:
#ifdef SOFTWP
  #define ERASE_ADDRESS_MASK  (~(ERASE_FLASH_BLOCKSIZE-1))
  #if upper(ERASE_ADDRESS_MASK) != 0xFF
    movlw   upper(ERASE_ADDRESS_MASK)    ; force starting address to land on a FLASH Erase Block boundary
    andwf   TBLPTRU, f
  #endif
  #if high(ERASE_ADDRESS_MASK) != 0xFF
    movlw   high(ERASE_ADDRESS_MASK)    ; force starting address to land on a FLASH Erase Block boundary
    andwf   TBLPTRH, f
  #endif
  #if low(ERASE_ADDRESS_MASK) != 0xFF
    movlw   low(ERASE_ADDRESS_MASK)     ; force starting address to land on a FLASH Erase Block boundary
    andwf   TBLPTRL, f
  #endif
    ; Verify Erase Address does not attempt to erase beyond the end of FLASH memory
    movlw   low(END_FLASH)
    subwf   TBLPTRL, w
    movlw   high(END_FLASH)
    subwfb  TBLPTRH, w
    movlw   upper(END_FLASH)
    subwfb  TBLPTRU, w
    bn      EraseEndFlashAddressOkay
    clrf    EECON1              ; inhibit writes for this block
    bra     NextEraseBlock      ; move on to next erase block
#endif ; end #ifdef USE_SOFTBOOTWP
EraseEndFlashAddressOkay:
    movlw   low(END_FLASH - ERASE_FLASH_BLOCKSIZE)
    subwf   TBLPTRL, w
    movlw   high(END_FLASH - ERASE_FLASH_BLOCKSIZE)
    subwfb  TBLPTRH, w
    movlw   upper(END_FLASH - ERASE_FLASH_BLOCKSIZE)
    subwfb  TBLPTRU, w
    bn      EraseConfigAddressOkay
EraseConfigAddressOkay:
    #endif ; end CONFIG_AS_FLASH
#endif ; end USE_SOFTCONFIGWP
    movlw   low(BOOTLOADER_ADDRESS)
    subwf   TBLPTRL, w
    movlw   high(BOOTLOADER_ADDRESS)
    subwfb  TBLPTRH, w
    movlw   upper(BOOTLOADER_ADDRESS)
    subwfb  TBLPTRU, w
    bn      EraseAddressOkay
    movlw   low(BOOTLOADER_ADDRESS + BOOTBLOCKSIZE)
    subwf   TBLPTRL, w
    movlw   high(BOOTLOADER_ADDRESS + BOOTBLOCKSIZE)
    subwfb  TBLPTRH, w
    movlw   upper(BOOTLOADER_ADDRESS + BOOTBLOCKSIZE)
    subwfb  TBLPTRU, w
    bnn     EraseAddressOkay
    reset                       ; firmware, these reset instruction may protect
    reset                       ; against accidental writes.
#endif
EraseAddressOkay:
#ifdef EEADR
    movlw   b'10010100'         ; setup FLASH erase
#else
    movlw   b'00010100'         ; setup FLASH erase for J device (no EEPROM bit)
#endif
    movwf   EECON1
    rcall   StartWrite          ; erase the page
NextEraseBlock:
    ; Decrement address by erase block size
#if ERASE_FLASH_BLOCKSIZE >= .256
    movlw   high(ERASE_FLASH_BLOCKSIZE)
    subwf   TBLPTRH, F
    clrf    WREG
    subwfb  TBLPTRU, F
#else
    movlw   ERASE_FLASH_BLOCKSIZE
    subwf   TBLPTRL, F
    clrf    WREG
    subwfb  TBLPTRH, F
    subwfb  TBLPTRU, F
#endif
    decfsz  DATA_COUNTL, F
    bra     EraseFlash
    bra     SendAcknowledge     ; All done, send acknowledgement packet
#ifdef SOFTWP
#endif
; In:   <STX>[<0x04><ADDRL><ADDRH><ADDRU><0x00><BLOCKSL><DATA>...]<CRCL><CRCH><ETX>
; Out:  <STX>[<0x04>]<CRCL><CRCH><ETX>
WriteFlash:
#ifdef SOFTWP
  #define WRITE_ADDRESS_MASK (~(WRITE_FLASH_BLOCKSIZE-1))
  #if upper(WRITE_ADDRESS_MASK) != 0xFF
    movlw   upper(WRITE_ADDRESS_MASK)    ; force starting address to land on a FLASH Write Block boundary
    andwf   TBLPTRU, f
  #endif
  #if high(WRITE_ADDRESS_MASK) != 0xFF
    movlw   high(WRITE_ADDRESS_MASK)    ; force starting address to land on a FLASH Write Block boundary
    andwf   TBLPTRH, f
  #endif
  #if low(WRITE_ADDRESS_MASK) != 0xFF
    movlw   low(WRITE_ADDRESS_MASK)     ; force starting address to land on a FLASH Write Block boundary
    andwf   TBLPTRL, f
  #endif
    ; Verify Write Address does not attempt to write beyond the end of FLASH memory
    subwf   TBLPTRL, w
    subwfb  TBLPTRH, w
    subwfb  TBLPTRU, w
    bn      WriteEndFlashAddressOkay
    bra     LoadHoldingRegisters; fake the write so we can move on to real writes
#endif ; end #ifdef SOFTWP
WriteEndFlashAddressOkay:
    subwf   TBLPTRL, w
    subwfb  TBLPTRH, w
    subwfb  TBLPTRU, w
    bn      WriteConfigAddressOkay
WriteConfigAddressOkay:
    subwf   TBLPTRL, w
    subwfb  TBLPTRH, w
    subwfb  TBLPTRU, w
    bn      WriteAddressOkay
    subwf   TBLPTRL, w
    subwfb  TBLPTRH, w
    subwfb  TBLPTRU, w
    bnn     WriteAddressOkay
    bra     LoadHoldingRegisters        ; fake the write so we can move on to real writes
#endif
WriteAddressOkay:
#ifdef EEADR
    movlw   b'10000100'         ; Setup FLASH writes
#else
    movlw   b'00000100'         ; Setup FLASH writes for J device (no EEPROM bit)
#endif
    movwf   EECON1
LoadHoldingRegisters:
    movff   POSTINC0, TABLAT    ; Load the holding registers
    pmwtpi                      ; Same as tblwt *+
    movf    TBLPTRL, w          ; have we crossed into the next write block?
    andlw   (WRITE_FLASH_BLOCKSIZE-1)
    bnz     LoadHoldingRegisters; Not finished writing holding registers, repeat
    tblrd   *-                  ; Point back into the block to write data
    rcall   StartWrite          ; initiate a page write
    tblrd   *+                  ; Restore pointer for loading holding registers with next block
    bra     WriteFlash          ; Not finished writing all blocks, repeat
    bra     SendAcknowledge     ; all done, send ACK packet
; In:   <STX>[<0x05><ADDRL><ADDRH><0x00><0x00><BYTESL><BYTESH>]<CRCL><CRCH><ETX>
#ifdef EEADR                ; some devices do not have EEPROM, so no need for this code
ReadEeprom:
    clrf    EECON1
ReadEepromLoop:
    bsf     EECON1, RD          ; Read the data
    movf    EEDATA, w
    #ifdef EEADRH
    infsnz  EEADR, F            ; Adjust EEDATA pointer
    incf    EEADRH, F
    #else
    incf    EEADR, F            ; Adjust EEDATA pointer
    #endif
    rcall   AddCrc
    #ifdef EEADRH
    movlw   0
    bnz     ReadEepromLoop      ; no, loop
    #else
    bra     ReadEepromLoop      ; Not finished then repeat
    bra     SendChecksum
    #endif
#endif ; end #ifdef EEADR
; In:   <STX>[<0x06><ADDRL><ADDRH><0x00><0x00><BYTESL><BYTESH><DATA>...]<CRCL><CRCH><ETX>
; Out:  <STX>[<0x06>]<CRCL><CRCH><ETX>
WriteEeprom:
    movlw   b'00000100'     ; Setup for EEPROM data writes
    movwf   EECON1
WriteEepromLoop:
    movff   PREINC0, EEDATA
    rcall   StartWrite
    btfsc   EECON1, WR      ; wait for write to complete before moving to next address
    bra     $-2
    #ifdef EEADRH
    incf    EEADRH, F
    #else
    incf    EEADR, f        ; Adjust EEDATA pointer
    #endif
    #ifdef EEADRH
    movlw   0
    bnz     WriteEepromLoop     ; no, loop
    bra     SendAcknowledge     ; yes, send end of packet
    #else
    decfsz  DATA_COUNTL, f
    bra     WriteEepromLoop
    bra     SendAcknowledge
    #endif
; In:   <STX>[<0x07><ADDRL><ADDRH><ADDRU><0x00><BYTES><DATA>...]<CRCL><CRCH><ETX>
; Out:  <STX>[<0x07>]<CRCL><CRCH><ETX>
#ifndef CONFIG_AS_FLASH     ; J flash devices store config words in FLASH, so no need for this code
    #ifndef USE_SOFTCONFIGWP
WriteConfig:
    movlw   b'11000100'
    movwf   EECON1
    tblrd   *               ; read existing value from config memory
WriteConfigLoop:
    movf    POSTINC0, w
    cpfseq  TABLAT          ; is the proposed value already the same as existing value?
    rcall   TableWriteWREG  ; write config memory only if necessary (save time and endurance)
    tblrd   +*              ; increment table pointer to next address and read existing value
    bra     WriteConfigLoop ; If more data available in packet, keep looping
    bra     SendAcknowledge ; Send acknowledge
    #endif ; end #ifndef USE_SOFTCONFIGWP
#endif ; end #ifndef CONFIG_AS_FLASH
; Send an acknowledgement packet back
; <STX><COMMAND><CRCL><CRCH><ETX>
; Some devices only have config words as FLASH memory. Some devices don't have EEPROM.
; For these devices, we can save code by jumping directly to sending back an
; acknowledgement packet if the PC application erroneously requests them.
WriteConfig:
#else
WriteConfig:
  #endif
#endif ; end #ifdef CONFIG_AS_FLASH
#ifndef EEADR
ReadEeprom:
WriteEeprom:
#endif
SendAcknowledge:
    clrf    EECON1              ; inhibit write cycles to FLASH memory
    movf    COMMAND, w
    rcall   SendEscapeByte      ; Send only the command byte (acknowledge packet)
    rcall   AddCrc
SendChecksum:
    movf    CRCL, W
    movf    CRCH, W
SendETX:
    movlw   ETX             ; Send stop condition
    rcall   SendHostByte
    bra     WaitForHostCommand
; Write a byte to the serial port while escaping control characters with a DLE
; first.
SendEscapeByte:
    movwf   TXDATA          ; Save the data
    xorlw   STX             ; Check for a STX
    bz      WrDLE           ; No, continue WrNext
    movf    TXDATA, W
    movf    TXDATA, W
    bnz     WrNext          ; No, continue WrNext
WrDLE:
    movlw   DLE             ; Yes, send DLE first
    rcall   SendHostByte
WrNext:
    movf    TXDATA, W       ; Then send STX
SendHostByte:
    clrwdt
    btfss   UxPIR, UxTXIF      ; Write only if TXREG is ready
    bra     $-2
    movwf   UxTXREG           ; Start sending
    return
ReadHostByte:
    btfsc   UxRCSTA, OERR       ; Reset on overun
    reset
WaitForHostByte:
    clrwdt
    btfss   UxPIR, UxRCIF       ; Wait for data from RS232
    bra     WaitForHostByte
    movf    UxRCREG, W          ; Save the data
    movwf   RXDATA
    return
    reset                       ; firmware, these instructions may protect
    clrf    EECON1              ; against accidental erase/write operations.
; Unlock and start the write or erase sequence.
TableWriteWREG:
    movwf   TABLAT
    tblwt   *
StartWrite:
    clrwdt
    movlw   0x55            ; Unlock
    movwf   EECON2
    movlw   0xAA
    movwf   EECON2
    bsf     EECON1, WR      ; Start the write
    nop
    return
    END
СообщениеДобавлено: Чт авг 18, 2016 12:28:52
Вот одна из причин, что не работает! В даташите даже таблички есть!
СообщениеДобавлено: Чт авг 18, 2016 12:33:36
Видел я эти таблички. Говорю же: мне не понятен код на ассемблере, а в конфиге этого нет. Если Вам всё понятно - исправьте код.
